It is currently Sun Jul 27, 2025 1:20 pm
 Post subject: sharpening router bits?
PostPosted: Mon Jun 02, 2008 8:37 pm
does anyone have a technique for sharpening router bits? at $20.00-$30>00 a pop it seems like a neccesity , thanks Jody
PostPosted: Tue Jun 03, 2008 12:20 am
Last Name: Garrish
If you don't need a bearing on it, my carbide mills cost me a lot less than most people are paying for HSS router bits and they essentially last forever cutting wood. Sort of a problem avoidance strategy, I suppose, but you can get a 1/2" 2 or 4-flute carbide end mill for under $20. It's crazy what the same cutters for for as 'spiral router bits'. If it's got a bearing on it then I've got nothing for ya unless you're fast enough to use the shank without burning...
Bob Garrish
PostPosted: Tue Jun 03, 2008 5:09 am
Thanks , it seems like a round diamond file ( and magnifying glasses)would work for round over bits too ... ! jody
PostPosted: Tue Jun 03, 2008 5:25 am
I use carbide end mills in my pin router - they give amazingly clean results. Love 'em!
PostPosted: Tue Jun 03, 2008 6:47 am
I bought a diamond sharpening wheel from a guy at the big wood shows who sells resharpened drill bits from the aircraft industry - those bits are amazing as well, and fairly priced. The wheel was 20 bucks I think ...
Anyway, the wheel goes in my dremel, and I have only used is a couple times, but it did a great job .. It saved the little 3/8 top bearing bit from SM for template routing from the trash this way. It had seen way too many PU routes, and was really dull .. no more.
Users browsing this forum: Bing [Bot] and 14 guests
